Can anyone advise please.
I have today changed one side, only took 3 and a half hours. That piston is a pain in the arse to wind back in. That took almost 2 hours. However I think I have a problem as the seal which sits around the piston come out when I retracted the piston with the brake pedal. I have managed to screw it back in but the seal seems to be sitting on the end rather then doing its job of sealing.
I have put the pads on and refitted the calliper. Put the wheel on, handbrake seemed very very loose so I pumped the brake pedal and it stiffened up again as did the brake pedal. I then reversed backwards and drove forwards testing the brakes. Seemed to work fine, very keen which is a good sign.
However there seems to be fluid coming from the piston still. Is this normal or will this be because the seal is not on properly? Or is it the built up fluid which is now coming out?
Don't want to drive and end up with no brakes.
