rear brake discs
b21playa
oil burner
Jan 10, 2005
544
Birmingham
think i will have to do these soon, looks lik they are not wearing evenly over the disc.
Ive looked at GSF and they were priced at £25.40, is that each disc or for an axel set?
where else could i try to get some cheap?
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
that will be each, saying that usually ask them what they will do as a best price face to face and they will knock a few quid off.
saying that if you can find a motoquip dealer locally they are usually cheaper my front discs were 50 quid inc vat so id expect the rears to be less by 10-15 quid.
b21playa
oil burner
Jan 10, 2005
544
Birmingham
expensive for a set of cheap disc.
only good thing about my last car (astra), i got discs and pads from dealer for less then £50
gonna hve to look around as im gonna need pads as well togo with them
gazjones
i got lucas disks and pads for around 40 quid try a local motor factors very widely used setup so lots of places should stock them
gazjones
the place i got them from were from stratford upon avo think the were called ferraris piston
b21playa
oil burner
Jan 10, 2005
544
Birmingham
finally managed to get them ordered.
purchased the ones off ebay in the end at £29.
Had a look at my rear discs and they are definately shot, got a lip of about 2mm now so dont think pad sits flush either, which causes handbrake and general braking to not be so good
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
i replaced rear discs and pads
came from mike @ motorserv
cost me 50 for discs incl pads and were here the next morning
Mar 26, 2007
2,020
S.Wales
i'd guess part of your 2mm lip is probably rust that has stuck to the outside, if you place a steel file firmly against the edge and spin the disc i reckon you will find a fair bit of that comes off.....discs are maybe not as bad as you think?
