rear bushes
hi i did this in the summer but you would be a brave man to try it now! lol
it is a pain to do, needs two people for some parts like putting the beam back in and a whole lot of shoving and forcing with the
help of a Jimmy bar.
i did it on my own and got my neighbour to
help with putting it back in it took about 5-6 hours
things you'll need to axle stands, jimmy bar, brake pipe clips, long bolt and washers(for pulling the bush in to beam)trolley jack,drill(for drilling the bushes out) socket set and general tools.
jack car up and axle stand at jack points as the beam will be coming out!!
remove wheels
remove brake pipes as the are attached to the beam and will stop you removing it!
i removed brakes as well but i was servicing them and putting new pads and disc while off but the main reason is that the beam weights about 80 pound and did not want to damage callipers as they are aluminium.
support the rear beam in the middle with the trolley jack when you undo the rear beam bolts i left the shocks attached at this point to
help support the beam then lower the beam to the ground then undo the shocks and pull out the beam
drill out the old bushes as the pressed in
remember which way the bushes go in!!! or you could really regret it later my advice is take one out and put the bush back in then do the other
you will need to pull the bushes in with long bolt and washers and a pair of pliers to brace across the beam hole for you to pull against once in restep your tracks and put back in car
the awkward bit is getting the beam back in and i would strongly suggest you get a friend to
help or their will be lots of shouting
go to b&q and get a long bolt and nut with some large washers this is what i used for pulling the bushes in across the gap on the beam put a large pair of pliers or gas spanner then wind the bush in !!! hope this
help
Eugene
