Rear ARB..help required
Neil_Ireland
Leon Cupra
Apr 27, 2006
311
Dublin
Hi all,
Could some one please post a pic of the circular metal bands which hold the bushes to the rear beam, I have eibach arb's and am not sure what way the bands go on.
It would be great if someone had a pic of the front most part of the rear beam so I could see the bands attached.
Thanks,
Neil.:D
Ju.
461
Bradford
Don't think it's that important as long as there tight!!
Neil_Ireland
Leon Cupra
Apr 27, 2006
311
Dublin
Thanks WeeJase.....
I tried to fit my rear arb today, had the bands the same way as yours and when I went to tighten one of them the spot welds broke [:@]
Eibach are posting me an new one but in the mean time I had both brackets spotwelded a few extra times from a sheet metal engineers.
Needless to say I was not in the best mood after that but I did fit my rear koni fsd's while the car was in the air. :)
Thanks,
Neil.
WeeJase
pert
Jun 2, 2001
8,595
little tip for ya.
loosely cable tie the arb into place,i found this much easier than struggling.
this was lay on back on my driveway.
WeeJase
pert
Jun 2, 2001
8,595
how do they differ?i've never seen a diagram as the 2 i have fitted have both been second hand.can't personally see it fitting any other way(easily)
andycupra
status subject to change
diagram in post 3. take a look.
other than the fact the clamp is fitted upside down in the photos, note the total lack of rubber strip in the photos.
the clamp is also fitted on an 'edge' rather than on a flat, so the forces put on this clamp are not as designed.
WeeJase
pert
Jun 2, 2001
8,595
the rubber strips are there in my pics,they are the rusty looking strips between silicone bush and strap.mines different because i found it easier to get it on that way.personally i don't see it being a problem,its just a glorified exhaust clamp afterall.
edit:is that eibachs actual diagram?if so the rubber strip they supply isn't long enough to go where they suggest it barely covers the poly bush as it is ,nevermind the widest part of the rear beam .
WeeJase
pert
Jun 2, 2001
8,595
it seems so,i'm going to have a looksie tomorow,its too dark now.but yes rubber doesn't rust,but the clamp does.
edit: again.they could be metal:redface: its been on long time now :D
