As Gokiwi said
They have a good influence on the rear tracking better.
I’ve also done the front as well
Mine is the Eibach version ( search TT version )
Fixed rear adjustable front.
Think that’s right. Either way it’s all set to stiffest.
That coupled with Whiteline racing drop links poly bushing on front with added castor ( Uber cheap mod and a goodie £45)
Makes the car feel like night and day.
Transforms the car, stiffens up the wheel generally,
Then in corners everything is that much more controlled and tight.
I’d say drive mine but .....
You’d be super surprised with the difference to stock set up.
Although now with even more bars and braces on it it’s quite a different beast altogether.
Guess what I want to say is you will really notice if you change the rear, if you do front too it’s a big difference.
Some say a softer front is actually better for corner entry.
If I hadn’t tossed mine away I’d have liked to see the difference going stock up front would make on track, as a suspension guru suggested it a while back.
Badger5 Custom Map + TIP,
