Hi, I recently bought this car and it had chewed up a set of rear tires so I went for an alignment and new tires. The alignment shop said it was way out of spec in the back, which cannot be fixed (because its a fixed beam/axle).
The alignment geometry is below (sorry, in Dutch). They didn't bother to fix the front because the back was so bad.
Any ideas of what may fix this, other than the rear beam/axle? Could worn bushing cause this much deviation, or a stub axle (not really sure what that is) problem?
Notice the bad tracking/toe and camber on the rear left wheel. Any ideas? Since the right is not too bad and the left is bad, could that mean only a problem in the left rear hub area?
wielvlucht = camber
sporing = tracking/toe
askanteling = caster
voor = front
achter = rear
links = left
rechts = right
actueel = before
vooraf = after (they didn't really make any adjustment, so this is not relevant)
specs is abvious
Thanks... this sucks.
wielvlucht = camber
voor = front
achter = rear
links = left
rechts = right
actueel = before
specs is abvious
