RCA Y Splitter dilemma
mattcogg1981
193
Burnham on sea, Somerset
Hi all,
I have recently installed my ICE into my new car and at the moment I have my 6x9s and Sub running off one set of RCAs with a Y splitter. When I fade the stereo front and back and left and right it doesn't work properly. I have a seperate sub out put on my stereo and in fact I have 3 RCA outputs in total 2 normal ones and the sub one being some wires coming out of the stereo. Would I get more control if I connected another set of RCA from my stereo to my sub and got rid of the Y splitter?
How this makes sense
Thanks in advance
MAtt
lard44
Watching C beams...
Apr 30, 2007
474
Braintree, Essex
In short, YES!
Chances are that each of the pre-outs can be controlled from the HU (which one is it?)
It's a little extra hassle but really worth it - all 3 of my pre-outs have RCAs connected and i can control pretty much the lot from the HU.
mattcogg1981
193
The left and right do work and front and back but the bass really fades out from left to right. I have a seperate sub control RCA lead which I am not using however because all is connected to the rear output RCA I can still adjust the bass. what benefits will the seperate sub control give me?
Icecavern
6,214
Berkshire, UK
www.icecavern.com
The bass fading out when you change left/right balance is because the amp is summing the two together and when one level lowers you remove some of the signal. If you have a sub control out then use that as it wont change levels when you fade the speakers.
mattcogg1981
193
Yeah bass goes up and down with volume at the mo! So basically I will get more control of my bass whcih is really what I want! I have an extra RCA set so will attempt to re-wire soon!
Thanks guys
