Rattle in passenger side door
ruida_silva
17
Last week I was driving and heard something falling and make a loud noise, couldn’t see a thing anywhere inside.
Anyway, today I realised that something must’ve fallen inside the door card as it rattles when opening and closing the door. Sounds metallic and somewhat heavy.
Speakers are working fine, door handle is fine and windows go up and down okay as well. What could it be? Can’t attach videos
ukwomble
12
So for now, avoid is using that window just in case?
Should be fine using it, it'll just be a little loose on mechanism, try different positions on window and see if it stops if so this is probably the reason for noise then you'll have to take of door card , find the bit that's loose and tighten up
Reactions: ruida_silva
