Hi guys, I have a small issue with the car (02 Ibiza Cupra R) which is starting to annoy me now!
Basically every now and again the engine will cut out, sometimes it will do it when pulling upto a junction (clutch dipped) other times will be when I've been manovering etc (dipping clutch to go from first to reverse etc).
The electrics are all still live after the engine has cut out and the car will restart and drive as if the engine never stalled.
I have checked the car for fault codes with vagcom and all appears fine.
Possible vacuum / boost leak?
Logged Boost etc here....
http://www.seatcupra.net/IbizaR/002_004_115_Martyn_Log_30_11_05.csv
Cheers,
Martyn
Cheers,
Martyn
