I was driving to the airport last week when on the way some of the dash lights flickered up for a split second, too quick to notice which ones, and went off again. Forgot about it and went on me hols.
Then, on the way back from the airport a couple of days ago the same thing happened, different combination of dash lights, but with a jolt through the entire car as if it stalled, only it didn't (I was doing 70mph at the time). Once again the lights were visible for all of half a second.
I've ran a vag-com error check on it, which was clear, and the battery voltage is as it should be (only thing I could think may cause it).
I had a sub installed about a month ago which has a feed off the battery, but surely that couldn't be causing it? A search has not been helpful either, anyone have any ideas?
