Raising Bonnet Hinges
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Im looking at raiser my bonnet hinges to allow more heat to escape from the turbo area...as my Engine bay is like a oven with the Bt Setup...
I done this with my old 2.0 corsa but can't remember how todo it..
Anyone now how or even with pics...
ibiza_95
1.8T MK2 Conversion
i think actually the hinges mount to the sides near the wing mountings... stick washers under these
kyle'87
Modding Disease
Sep 15, 2008
868
Ruislip
I would get a pic of mine, but its pissing it down!
Just undo the two bolts and replace with longer ones and use washers to jack up the bonnet, careful tho re-aligening the bonnet.
RichStew
Yeah you need to separate the hinges i used larger washers both sides to stop it pulling through the hole and i used larger diameter nuts to space them with longers bolts.
it needs to be done in a ratio of front to back eg bolt nearest windscreen took 2x washers and 3 x nuts whilts bolt nearer front end was 2x washers and 2x nuts to give it the lift.
Carefully to re-align the bonnet when tightening as it wont shut and catch the wings, its a two man job really.
Will post pics up when i can mate
daves ibiza
danny mate mr d had proper ones but mines was just as good lol he told me to use washers under hinges couple under each and bam theres your bonnet lifted hope this helps
daves ibiza
depends how you want it mate really i had mine only raised a bit . ive seen some cars and it looks awe full lol . but now my bonnet is knackerd i took them out as it made it look worse. bonnet flipped open and creased passenger corner:banghead2
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
25mm ones on my ibiza (max allowed in regs) to help let some airflow/heat out there... however, the base of the windscreen is actually a high pressure area when at speed to whether or not there's any actual airflow coming out of the engine bay at speed from the rear edge or not I'm not sure..
Dan1.6
1.6 Power FTW!!!!!!!!
Sep 26, 2008
981
Chesterfield
i did this to my 1.4 i just got some steel from work unbolted one of the hindges put it underneath marked it drilled it and then got some longer bolts and job done
