Radius vs tapered spacer bolts
HumanSteamroller
26
Hello all,
Once again consulting the SC.net hive mind about wheel related bits.
I'm looking to put 15mm spacers all round on my 2015 Seat Leon FR. Specifically these from DPM: https://www.dpmperformance.co.uk/ca...5f-pcd-5112-centre-bore-571-bolt-thread-14x15
Question I have is, do I need tapered or rounded bolts? My Leon is still running the standard 17" five spokes for now, pending a BBS upgrade at some point. But for now, just looking to space the OEM wheels I have.
Thanks guys!
Legojon
I only wanted a remap
5,316
2,748
Not sure. Best bet would be to post in the dpm section of the forum. There's a couple of recent threads in there on spacers. But I think they are for MK2s. But drop your question in there, they are usually pretty quick to respond.
ecklad
Lord Edmund Blackadder
The wheels are not changing so you need the 'radius seat' bolts as your standard bolts are, just 15mm longer..DPM supply a set in the spacer kit. just select the radius seat bolts when you order them
The only items you might struggle with is the locking bolts.
Reactions: Walone
