TDI Powerrr
Last week I had a starter motor problem where the wires pulled themselves free from the waterproof terminal, so i disconnected the battery, took battery out to gain access to the wires.
Striped plastic back re-wired etc, jobs was a good'un, turned on the radio and it asked for the code. I put in what i thought it was, i was wrong
Found the correct code, tapped it in, thinking when i did all 4 numbers it would start up straight away without needing to press "enter" or whatever, but it didn't.
So now it won't do anything, it just says "SAFE" and what ever buttons i press (and ive tried all of um) nothing takes me back to the code entry bit. So i disconnected the battery and left the car for a couple of hours in the hope that it would allow me to type the code in again. It didn't.
The miles and trip computer were reset, but the radio is still saying SAFE and all i have to listen to when i drive to work is diesel!
Any suggestions, i'm reluctant to take it to a stealership cus they may go, "ah no we cant look at it now we'll book you in" and then charge me the earth.
Thank you plz
Thank you plz
