Rad hose filler neck
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
I apologize if this isnt the name of the item im looking for but i havent got a clue what its called!
Basicly im now gathering the bits to go k03s hybrid so im going to have to use an LCR tip which is fine but i dont perticuly (SP) like the fact that you have to move the coolent bottle under the TIP, i`ve seen on Philw`s car that he has some sort of pipe that he has inline with the rad pipe where he is able to fill his coolent from does anybody know where i can get one of these and what the actual name of it is.
Thanks in advance.
PS polished header tank for sale soon ;)
Nov 2, 2004
9,335
South Wales
That header tank will have changed hands a few times now!
Its exactly what you called it, a filler neck, i got mine from a trader on E38 with the cap, nice piece of kit as well. I think demon tweeks sell them as well.
I posted some pics of it in that section on e38 under my other name PDub.
I used the standard top rad hose and cut away a section to fit the filler neck, easy enough.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Any ideas on hose size people before i whip the hose off in the morning?
Is this the same kind of thing you used Phil?
Nov 2, 2004
9,335
South Wales
Yeah thats the filler, i got a feeling its 1 1/4 both sides, but dont quote me on that.
Funny tho, was looking at Stant lever caps for these in Walmart last week in colorado, only 8 dollars as well. lol.
You goin to UD? You still got my number? Gimme a buzz ill be there.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Spot on, ill have a double check just to make sure.
Nah not going now my lift couldnt make it.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Me more than the car i hope... :gay:
It was 1' 1/4 both ends i manged to dig out my old top rad hose.
How do you go about telling the level of the coolent when using this?
Im hoping that the one from Demon tweeks comes with the cap for £40!
Blue top rad hose for sale soon :D
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Ok guys help me out here im a little confuzzled!
I got my filler neck today and got a standard radiator cap to go with it..
Now ive had a look at phils in his bay and i cant seem to see if he has a nipple on his or not.
Do i need to block that nipple off or does the top hose from the header tank connect there? Im abit worried if i connect it there that its going to pump coolent in but wont be able to get out as the cap has a spring and rubber seal on it, which in turn could cause it to explode due to pressure?
Anybody:(
