Quick 'Q' about Foam Guns
foxes
539
Bang In The Middle.
its a Gilmours foam gun.
tried to experiment with shampoo but its not that thick as foam, its quite watery.
i have tried various settings.
cheers
Empi5
Your scaring me.......
Feb 24, 2005
2,807
Staffordshire
I found with a foam gun, using a standard hose pipe, the pressure is not sufficent to aggitate the foam.
Hence using snow foam, with a pressure washer, hummm luvly thick suds
Aug 30, 2004
662
Stockport
Explain Phil is Snow Foam a washing product or is a system? :confused:
Can it be used with a conventional pressure washer or do you need some attachments?
See you at the Hilton, Silverstone weekend.
Keith
MarkE
Acceptable in the 80s
Jul 20, 2003
1,705
Lancaster
www.markeaston.org
Snow Foam is a product :
CLICKY
It will work fine with the standard Karcher foam gun but people tend to think that the foam is thicker using a Gilmour.
I use Meguiar's Hyper Wash in the Karcher foam gun and I'm more than happy with the results. Dilutes 400:1 so the gallon I bought should last a while...
Empi5
Feb 24, 2005
2,807
Staffordshire
It does say that the Gilmour only requires a hose pipe, i cant understand where the pressure would come from...... Surely it would have to be of power washer proportions.
