Quick intro (1.2 TSI and 6-speed experience) and can answer questions ....
rdraheim
84
16
Hi All!
Just picked up a 2015 SEAT León ST Technology w/48k on it. Also have a VW Golf S from 2011 with 151k on it.
I've built up quite a knowledge base of both the EA211 and EA111 1.2 L TSI engines (CYVB for the EA211 in the SEAT and CBZB for the EA111 in the Golf). Both cars also have the 6-speed 0AJ MQ200 gearbox ... LHY code in the Golf, not sure in the seat.
I have 151k on the chain-driven CBZB, which I believe was also offered in the SEAT and I've had to replace the entire transaxle in the Golf due to a sheared bolt-head in the differential, so I have some experience with the 6-speed 0AJ as well.
Anyways, I wanted to read around here and thought I'd make an account as well :D
Cheers!
Aaron75
11
Hi I have a see Leon 1.2 TSI DSG 2014.
Just reached 100k miles. It has full service history, drives faultlessly; powerful no hesitation. However i have the dreaded oil consumption; in particular motorway journeys where it’s more discernible.
A 300 mile round trip can see a drop of a litre. It’s mind boggling because there’s no visible leaks, no blue or white smoke from exhaust, or any oil residue in exhaust ? I’ve topped up with 5W/40 so I am using to right Oii grade.
Any guidance would be appreciated,
oil breather location ? Try that first or any other suggestions ?
Big Vinny
226
49
Isn't the correct grade of oil for the 1.2tsi engine 5W30 or 0W20. 5W40 would be extra viscous (thick) ?
I have seen an online report that the 1.2tsi starts to use oil at around 60k miles when the oil holes in the piston/control ring become blocked. I can't verify this though ? Maybe using an overly viscous oil is a contributory factor to your oil consumption issue.
I have always used Mobil 1 esp 5W30 without any issues.
