Question about VAG-COM and lights
vtxracer
420
13
Greece
I have a 2009 Ibiza FR TSi. I would like my city/parking lights to become Day Running Lights. Is it possible ?? (with Vag-com ??)
leynard84
Hello. I have an Ibiza 1.6. I want to activate the 'day running lights'. How can i do it ?
S3 AKR
livin' the dream!!!
Jun 30, 2004
1,453
Colchester, Essex
I would have thought you could do it. There is a setting for my VRS that allows it.....Scandinavian Lights setting. The Skoda detail is below but be careful in using these "instructions" on your car as they may not be correct. Vag-com does have good label files for the Skoda that allow you to confirm what it is you're changing when using "long codes" - not so sure about the Ibiza - so just be cautious. Use these instructions to have a look around to find the right location for what you're looking for.
Puddle lights on door mirrors
42 – Door electric (driver)
07 - Recode
Should read 756 on ambiente models
To add Puddle lights +2 (758) (Std on Elegance)
Steering weight
44 – Steering assist
10 - Adaption
Channel 1
Should read 5 on non Vrs models. Pick a number between 1 & 6 for steering weight
For auto lights
DISCLAIMER: you need rain sensor wipers and test with someone elses tunnel light switch before you buy one as it may not work properly
09 – Central electrics
Long coding (07) , click yes when asked
Byte 1 – highlight ‘assistance driving light_leaving home active’and ‘coming home active.’
Transfer coding.
Single door unlock
46 – central convenience
10 - Adaption
Channel 3
1= on, 0=off
Anti hijack
Auto lock
10 - Adaption
Channel 4
1= on, 0=off
Auto unlock (when you take keys out of ignition)
10 - Adaption
Channel 5
1= on, 0=off
Alarm horn change
10 - Adaption
Channel 13
1= Rest of world
2=UK
Activate cruise control
16 – Steering wheel
07 – Recode
00xx?x
0 = no CC or maxidot
1 = no CC with Maxidot
2 = with CC, no maxidot
4 = With CC and maxidot
Instument options
17 – instruments
07 – recode
00??x0x
00 = no options
+01 = brake pad monitoring
+02 = Seat belt warning
+04 = Washer fluid warning
(add the option numbers together for the right number i.e: all three = 07 or to turn off seatbelt warning 01+04=05)
Long coding options (other stuff is possible, but either not worth it or a bit dodgy)
Central electrics (09) (Long coding options)
Byte 1
Scandinavian lights (always on)
North America lights (front lights on with handbrake off)
Leaving home lights (lights come on for 60 secs when door is unlocked)
Coming home lights (lights come on for 60 ses when door is locked) (for some reason I cannot get this to work)
Byte 3
Rear fog lights (highlight for 1, turn off for 2) (1 foglight is dependent on left or right hand drive)
Reverse lights (same as rear fogs, single reverse light opposite side to single fog lights like with cars with one of each)
Reverse driving lights off when boot open (don’t see the point apart from saving the bulb)
Byte 4
Activation of 2 rear fogs
Byte 17
Emergency brake light flash active (not tried it, but some Peugeots have it, when the brakes are put on hard the brake light flashes)
Front fogs deactivated with main beam (With Fog lamps on, the turn off when main beam is switched on)
46 – Central convenience long coding
Byte1
Single door opening
Auto lock
Auto unlock
Byte 4
Power window open and close by for or key (on and off)
Byte 6
Unlock beeps and indicator blink through key and remote
Byte 7
Lock beeps and indicator blink through key and remote
Byte 8
Activation of anti theft warning system with beeps and blinks
Byte 9
Synchronised mirror adjustment (turns on and off the right side mirror adjuster moving both mirrors)
Byte 11
Siren tone type (on = Rest of world, off = Uk )
Alarm siren type ( on=short length, off= long)
