Short version: Can a bad coilpack prevent the engine from starting/idling at all without helping it with the accelerator?
Long version:
OK so I've recently removed my SAI, N112 and N249 and replaced with resistors, fitted a catch tank and phenolic insulator gasket, while having my rocker cover, inlet mani and some other bits sent off to be sprayed.
I put it all back together yesterday and it was idling fine when I first started it. Went to go out last night and got 1/2 mile down the road before it started misfiring - classic sign of a coilpack I thought to myself.
Brought it back and it was still idling, just very roughly. So disconnected each injector connector one by one and found that cylinder 2 was my culprit.
So this morning I found a spare coilpack that I had been keeping in the boot and swapped it over but still no difference - however I have never tested this coilpack and it has been rolling around loosely in the boot for nearly a year so I can't say whether I'm swapping it for another bad one
I then ran VAG COM and found the following:
10 Faults Found:
18011 - Internal Control Module Failed Self-Test
P1603 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1 Misfire Detected
P0301 - 35-00 - -
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
16687 - Cylinder 3 Misfire Detected
P0303 - 35-00 - -
17645 - Fuel Injector for Cylinder 1 (N30): Open Circuit
P1237 - 35-10 - - - Intermittent
17646 - Fuel Injector for Cylinder 2 (N31): Open Circuit
P1238 - 35-10 - - - Intermittent
17647 - Fuel Injector for Cylinder 3 (N32): Open Circuit
P1239 - 35-10 - - - Intermittent
17648 - Fuel Injector for Cylinder 4 (N33): Open Circuit
P1240 - 35-10 - - - Intermittent
17658 - Fuel Level too Low
P1250 - 35-00 - -
Now I believe I can discount the injector open circuits for me disconnecting each one to find the cylinder that was misfiring? Leaving me with a misfire.
NB - There's a code for fuel level too low but I think this may be where it was on axel stands on the front for over a week. It has 1/8 tank but is on the light admitedly - however as I'm getting faults for misfires on individual cylinders then I think coils are more likely
My other feeling is that it may be an injector as these were also removed and re-seated when I took the inlet mani off to be sprayed and to remove the PCV valve when fitting my catch tank.
Anyway....
I then cleared all codes and went to start the engine again to get a new set of more precise faults but this time it wouldn't start without a lot of help from my foot on the accelerator and as soon as I let my foot off it splutters and then dies again.
Would a single faulty coil prevent the engine from starting?
I then decided to swap the coils from cylinders 1 and 2 to see what difference this made and still the same. When I re-ran VAG COM I got a misfire on 1 and 2 (using the spare coil) so I suspect that this spare coil may also be bad???
As nowhere is open on a Sunday I've now had to call out the RAC to come and swap them for some new coils to see if this is in fact the problem...
Long version:
10 Faults Found:
P0300 - 35-00 - -
P0301 - 35-00 - -
P0302 - 35-00 - -
P0303 - 35-00 - -
P1250 - 35-00 - -
Anyway....
