Is it better to run your engine on almost no torque (meaning you change into a higher gear sooner rather than later) or is it better to keep the torque when driving at around 2000rpm (only changing gears when you get too much torque) ?
I got a 81kw Leon with max 4300rpm and since i'm still learning to drive properly i'm not sure what to do.
My father who has been driving for 20 years now says i should change into a higher gear often and not let the engine go above 2000rpm.
Anyway, i thought i'd ask you guys aswell; good day.
