putting a 130pd engine in my 110 tdi non pd
brad1
hi all
i have done so much to my car that i dont want to let her go, well she will be with my for at least another 4 years, i was just wondering would a 130 pd engine fit straight into my 110 tdi non pd????
or is there stuff which is different
cheers
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
It will "fit" - but getting it running will take a hell of a lot of work - Likely to need the following from the pd130 donor
Dashpod
Ignition barrel and key
Wiring looms
ECU
engine mounts
gearbox & driveshafts
basically, you need a whole wreck to get all the bits from. :)
cheshire cat
1,813
cheshire
Dashpod
Wiring looms
ECU
engine mounts
well that cost would buy an awfull lot of goodies I'd stick with it, a 130 would only be a starting point, and it looks like you already started!!:D
Viking
Insurance co's are crap.
May 19, 2007
2,317
Near Richmond, North Yorks
Dashpod
Wiring looms
ECU
engine mounts
And don't forget the all important 6 speed gear knob, otherwise you'll only be able to use 5 gears, and then there'll be the fuel pump in the tank aswell.
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
LOL - I actually did have to get the 6 speed gearbox base and linkages for my conversion as the 5 speed one was putting the 6 speed box into all the wrong gears! :lol:
Yeah - I guess the fact the PD uses injector pumps, and not a traditional fuel pump like the VE engines will be a factor. I expect you will probably need the complete PD fuel tank from the donor car. I would also try and retrofit the undercar fuel cooler.
Aug 1, 2005
2,695
Cullompton . Devon
Personally i wouldn`t bother at all. By the time you get all the donor parts and piss about fitting them to a registered 110 TDI which will then be worthless you could buy a good clean PD130 and put new mods on it and not have any hassle.
brad1
cheers for all you help guys, looks like in might just sell the car is 3 - 4 years to come and get the 150 tdi etc
