problems with turbo
mattfas
97
leeds
i have a seat leon fr 1.8t im having problems with turbo boost when under heavy acceleration in 6th gear the car seems to hesitate it doesnt boost properly the car jerks slightly like im pressing the accelerator up and down it only does this in 5th or 6th gear on motorway under heavy acceleration could it be the maf sensor
evokid
87
I had a similar thing on my Audi TT.....I cleaned Maf sensor and changed N75 valve....Fixed mine....But could be any number of things....Boost leak / N75 / Maf sensor / Coil pack? etc etc:rolleyes:
mattfas
97
leeds
d valve and coil packs
thanks for the replies i recently changed all 4 coil packs because 1 went faulty i was running the car with a split r dump valve on it but changed to standard one as i am trying to sell the car it has the fault with both dump valves the bosch one and the split r what is an n75?cheers
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
just out of interest put your split r dumpvalve back on, but this time make sure its fully recirculating.
i had the same problem with mine. it was down to a leak in the dumpvale. when i put mine back to fully recirculating it worked fine. by the way i tried everything before, changed th n75 valve, new maf and filter.still didnt fix it. it was the dumpvale all along.
