Problems fitting dump valve - help!!
wazo786
59
My carbonio CAI and 007 Forge DV arrived this morning and i am just back from the garage.....with only the CAI fitted!
The mechanic who worked on my car said that he could not fit the DV as there was no pipes etc in the box and it didnt simply replace the standard DV.
From the impression i got from awesome gti and other members - im sure that the 007p should fit straight onto the pipes etc from the standard one
Hes told me to go and buy the pipes and then he will fit it, but im convinced hes mistaken!
Can anyone shed some light on this issue please??
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
hes mistake, it definately works fine as long as you have new jubilee clips. he must be thinking of actually making a new location for one when its already on the turbo intake pipe.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
the guy who worked on ur car is a muppet!
the standard DV and forge DV are the same size... fit it urself its easy... there are 3 pipes... one from turbo charge pipe, one from the TIP and the vacuum pipe...
just look at the standard DV, take it out and fit the Forge urself... very self explanatory!
wazo786
59
im not good with engines AT ALL, so i think ill pass on tryna do it myself!
hes a good friend so does it all on the side for me (fitted CAI for 20 quid and sed he wudnt charge extra wen i took it back for DV)
ill pop back in tomorrow morning with the car and get him to fit it - might take a printed copy of the DV instal guide from leoncupra.co.uk for him to see
i think you are right - im sure from what he was showing me that he was planning on putting the DV in a whole new location because he was showing me it was goign to be fitted onto a completely different area than where the standard one is!
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
good idea... print pabs guide out and show him!
if he doesnt fit in less than 30mins then find a new "friend"! ;) :whistle:
Pabs
5,936
Basingstoke
hehe - yeh, its a piece of cake - so if you really need to take a copy of my guide, or just a couple of the photos to show where it goes.
Sounds like he is a bit of a muppet though - its virtually identical in shape to the original!
wazo786
59
so basically the 3 pipes that come out of standard one go straight into new one??
i sent you an email from your webpage aswell pabs, never knew you were on the cupra forums
is it possible to fit it without having any jubilee clips??
i doubt he will have any but im sure he will have other clips lying around seeing as its a car garage!!
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
the original jubilees are single use ones, any garage or halfords sell jubinees, you could take the dv in with you and trial fit them, two are roughly the same size and one is a lot smaller from memory 2x 22-33mm and as I said one that is a lot smaller, in fact a cable tie pulled tight may do the job.
si-mate
Jai Ho or Jay Ho?
May 31, 2004
941
Kunt Centryside
If he couldn't do it first time around then I wouldn't bother using him do it yourself. It really is very, very easy. As Brendy says go to halfords first for the jubilee clip - I think they do a selection box of assorted sizes so you should be covered for every eventuality.
The two things to watch out for are getting the single use clip on the top (vacuum) pipe and pulling it away from the two larger hoses.
satilaboy
375
what do people recommend between the bailey's dv30 and the forge 007? and are there any differences between them. i've done a search but nothing really on differences if any.
also, what spring is recommended for stage 1 revo???:
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
723
cumbria
www.facebook.com
wazo it really is dead easy mate ,i'm a novice around engines and after a quick read through of pabs guide done it in bout 20 mins,only because 2 of the original clips were pigs to get off,that mechanic must be a right arse:whistle:
wazo786
59
hey guys, cheers for all the help
just to shed some light - the mechanic is a trainer ex mercedes benz head mechanic for central scotland - and i doubt he gets many Mercedes customers asking for DVs:lol:
Told him that all of you say it should fit straight on and he said he wasnt aware i wanted the old one replaced and that he thot i wanted the new 1 fitted on a seperate part of the pipe!
that is why he said he needed more parts!
im taking it back 1st thing (hes round d corner) and hes going to sort it out, said it would take him minutes
Cheers:clap:
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Cheers:clap:
so he wanted to run an uprated DV along side the OE one?! :shrug:
or was he planning on removing the OE one as well?! :confused:
hope u get it sorted m8! ;)
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
he does sound like abit of a muppet, and not much of a friend if he charged 20quid just to fit an induction kit
if you want something done right, do it yourself. its easy when you know how
wazo786
59
got it all sorted this morning - sounds awesome, but dont think the forge added much to the noise - i thot it would
all the noise is being made by the carbionio induction kit! (sounds like darth vader)
i wouldnt feel right not paying him, so i would rather he took 20 quid than not take anything at all
its a CAI, so lil more work involved than fitting a normal induction kit
