Problems after remapping Ibiza Cupra TDI160
e3077
Has anyone experienced problems after remapping of this car?? - other than clutch problems :)
bellautos
Ive mapped about 34 of these this year all with no problems (so far)
What problems are you having OR is this just a general question ??
e3077
Just a general question - Im think of remapping mine, but I don't want to blow anything up :)
e3077
Bellautos>> With what result have you remapped these TDI160's - hp and torqe??
bellautos
The last one i made/rolling roaded did over 50bhp and could of held well over 400nm of torque ,
BUT as you all know the weak point is the clutch so i had to lower the torque to cope with the power.
bellautos
PS where abouts are you ??
I may be able to advise of a good tuner over there local to you.
DIFT
Torquing all the Torque
Oct 8, 2004
1,546
Kent/London
No problems with mine, done 35K since having it done (including several trackdays and going down santa pod a few times), clutch is a little worse for wear at the moment though.
spidermonkey
Should you always change the clutch when you get a remap? Can't the standard one cope? Should it be an uprated clutch or just a brand new one?
vwpologti
261
take it to pete at bellautos when you have it done,
this is the second time i have used pete and i now wouldnt
use anyone els!
sssstew
Editing your spelling
You dont always have to change the clutch, only if the remap cant be adjusted to lower the torque so it doesnt slip so much. The standard one can cope with a not to higher torque mapping, if its remapped to the best then it will make the standard clutch slip, if this is the case then a new uprated clutch should be fitted.
