Apr 25, 2022
8
Hello. I have weird problem with my lights. This happened after installing leds. But when I switched back to original w5w bulbs (which worked perfectly fine before switch (but they were old and needed replacement because it was literally dark inside the car at night time). the problem still appeared. So as on video. My front lights are not working properly and 1 bulb just dont want to light up at all. Car detects that the door is opened because it shows it on my dash and rear lights are working fine as on video. IMPORTANT: I noticed that when I try to switch light modes in front light the rear lights are flashing for a second everytime I press the button like there is some short circuit problem. I have no clue what this can be. Any help is welcomed
link to video: https://www.youtube.com/shorts/yvWEzIef_Hc
Apr 25, 2022
8
Corrosion inside the holders?
You mean the front overhead ones which hold the bulbs? Those looked pretty fine when I was replacing them. Car isnt very Old its 12 years Old. I dont think that its the case but I will check it to make sure.
