Problem with Accelerator Position Sensor
manhota
275
west mids wolves area
Hi all
Had a intermittant problem the other day just driving as normal and the engine protection light comes on and the car loses boost, swiched it off and on everything is normal again no weird noises happy driving and then it happens again at traffic lights under light throttle, i got her to my misses house and left her to sit for a couple of hours. I got back in for the drive home a good 70 miles and the engine light never came back on and most of it was at steady speed on the motorway.
a few days passed no problems and then it happened again today at trafic lights, i got her home and vagcom showed the below error.
thinking its gotto to have somthing todo with the accel pedal i touched the wires come out of the plug above the pedal jiggled it and the engine protection lights turned off!
Does this mean the plug just needs a clean or a new sensor?
VAG-COM Version: Release 704.1
Data version: 20070422
Wednesday,02,November,2011,13:15:04:10074
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: xxxxxxxxxxxxx Mileage: 75610km/46981miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.LBL
Part No SW: 1P0 907 115 D HW: 1P0 907 115 D
Component: 2.0l R4/4V TFSI 0020
Coding: 0303000318070160
Shop #: WSC 75242
1 Fault Found:
008504 - Accelerator Position Sensors (G79) / (G185): Implausible Correlation
P2138 - 008 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 0
Fault Frequency: 5
Mileage: 75450 km
Time Indication: 0
Date: 2000.00.00
Time: 19:22:52
Freeze Frame:
RPM: 3178 /min
Load: 12.5 %
Speed: 28.0 km/h
Temperature: 65.0°C
Temperature: 32.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.351 V
Readiness: 0000 0000
Marshall
3,256
Bonnie Scotland
Think a pedal is about £70 and you could fit it yourself its only 1 bolt and 1 plug would only take 5 minutes.
Sent from my HTC Desire using Tapatalk
MadMarkDH
I had the exact same problem two days after picking up my 08 FR diesel.
It was back in the garage for a full day that also involved a 60 mile 'test' drive!
All they said was that the Pot had gone. It was under warranty luckily.
