Problem when accelerating at speed in 6th gear
james12
78
This has happened a few times now and i've only noticed it in 6th gear.
It happens when cruising along on the motorway or dual carriageway at around 70mph or so in 6th gear... When accelerating from around 70mph the engine judders/hesitates like a miss fire feeling, no lights on the dash or anything.
I don't have anything for fault reading but the car is under warranty so will be phoning the dealer on Monday to get it booked in to try and find the cause.
Any known causes for this on the 2.0 CR engines?
james12
78
Hopefully nothing major, at least it's got a 6 month warranty with the Seat dealer.
james12
78
Is it possible this issue could be linked to the DPF? Quite a few results on Google of people mentioning juddering on regen cycles?
currie09
153
Mines does this as its sitting just as the turbo boosts, once you get over 2k revs just pulls like normal? Maybe just the car labouring?
james12
78
The engine wasn't labouring as it was still doing it even when the engine speed was above 2k rpm with the turbo on boost. Didn't feel pleasant at all so I backed off and it stopped.
jasons76
45
Mine did this all of a sudden one day last week,just after I had filled up with fuel,at first I thought it was bad fuel but it did seem to clear itself I wonder if it was doing a regen as it has been ok since.
james12
78
Never had a diesel with a DPF so I can't compare to anything how the car behaves whilst doing a regen. Whatever it was I didn't like it!
jasons76
45
Me neither I started to doubt myself and wondered if I had put petrol in by mistake I thought it was going to die on me.
james12
78
I think the DMF may be on its way out as when I started it this morning there was rattling/knocking noise coming from the engine, sounded like the DMF and a very similar noise to my vRS before it had a new clutch & DMF fitted... Not sure if it could be connected to the issue I posted the thread about. Going into the dealers on Thursday morning so they can have a look into the juddering, will also mention the noise I heard this morning...
james12
78
Exeo was in the garage yesterday and they told me the juddering was the DPF trying to do a regen... They've carried out the regen and it's now down to 0%. Probably won't need to do a regen cycle for a little while so will see if the juddering continues.
They also think the rattling/knocking noise I heard starting from cold was related to the DPF but I'm not sure about that, will just have monitor it as I think it's the early symptoms of DMF failure...
jasons76
45
how is it going since the garage visit,i think the juddering on mine is the regen,it only does it once every 500-600 miles or so and doesent last long but I only notice it on the motorway at 70mph,what did they say about the regen?
