francey
Ok so i currently drive an old 1.6 cordoba (AEE engine) as a runabout while my other car gets repaired now the cordoba only cost a few hundred so not expecting greatness but have had a couple of probalems and hopefully someone can offer some advice. I do not really have much experiance with mechanical issues so please be patient lol. ok so on wednesday my car overheated and i had to allow it to cool . since then i have been driving with the heaters on full and this is keeping the engine temp around where it should be. (i only mention overheating incase it is relevent)
anyway when driving tonight my car cut out i tried to restart it but engoine kept cutting out it appeared to be making the right noises (the battery had power and the starter appeared to be turning over) i tried bump starting to know avail. i again tried starting and this wouldnt work so i had a quick look under the bonnet and i found the the wire going between the Coil(i think) and the middle hole in the distributor cap had basically melted off at the cap end. the connector is still on the cap but the wire as come away from it and definatly appears to have melted. now i am not sure if this is linked to the overheating and i had no tools to get access to the distributor cap and have a look inside. i plan on finding out what i can tonight and seeing if there is anything i can do tomorrow, i dont have the money to go to a garage. My main question is if anyone has any idea what has caused this(could it be because it might not have had a recent service?) i also want to try to figure out potentially what further damage may have been caused i.e. do u think a new rotor arm etc will also be needed?
any help and advice however small is very much appreciated
thanks
thanks
