Pressure washer for use with water butt?
Paul_W
Newbie
Jul 23, 2006
114
Rutland
Can someone recommend a decent pressure washer that is able to draw water from a water butt rather than a tap? I heard some some Karchers do but not sure if they all do. Can they all do it out of the box or do I need to buy extra accessories to do it?
Craig Senior
I've been Tango'd
May 24, 2004
1,099
Yorkshire
Guy at work got a petrol washer for ebay for about £60 that he takes with him to Motorcross races, runs fine from a water barrel in the van.
Craig Senior
I've been Tango'd
May 24, 2004
1,099
Yorkshire
No probs.
I would assume that most washers would work from a water butt if they were connected to an outlet at the bottom and had a decent enough amount of water to draw from rather than being connected to a pipe dropped into the butt.
Does that make sense?
Paul_W
Newbie
Jul 23, 2006
114
Rutland
That's what I thought. But I remember seeing some advertised a few months ago that worked just buy putting a filtered feed pipe into the butt. Can't find any now that even advertise being able to use a water butt at all. I'll keep searching.
MarkE
Acceptable in the 80s
Jul 20, 2003
1,705
Lancaster
www.markeaston.org
It connects to the machine where you'd normally connect your hosepipe and has a filter on the other end, so doesn't require a machine with a dedicated inlet.
Google "karcher suction hose" for more info.
