PowerGasket (thermo Gasket)
ian_cupra
i bought the one off bill, bit better than the power gasket, i've had both
Jun 26, 2008
849
Sunderland
I can't see how this would work. Surely the air will heat up anyway when it comes into contact with the cylinder head casting, and that just as much heat will be transferred to the manifold by radiation as by conduction through the gasket.
Not saying that these don't work, obviously, i have no experience with them, and no offence to anyone who uses one and does get gains.
Would just like to know what I'm missing?
ian_cupra
simple physics lesson really! less conductive material than standard, so the heat wont transfer through from the head to the manifold with this gasket on :D
Jun 26, 2008
849
Sunderland
Of course, I was just wondering if the air could be that significantly cooler and if much of a power gain could be made whan the air is going to come into contact with the cylinder head after it leaves the manifold?
ian_cupra
well you think, if the inlet manifold is allowed to heat up, the air passing through will heat up also, so keeping it cool will reduce intake temps a fair bit :D
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
remembering the AIT sensor lives in the inlet manifold just afte the throttle body so sits in an oven, which is what it will be telling the ecu also... hot hot hot
