Power steering, traction control and tyre pressure warning lights!!
optim8
Over the last month or so my power steering, traction control and tyre pressure warning lights come on intermitently whilst driving. They all come on together and then generally will all go off together a few minutes later though the power steering does go off first on occasion.
Definetly seems to be outside temperature related as hadn't happened for weeks when the weather was warmer.
Anyone else experienced anything like this? Any ideas what it could be? It's doesn't make the car drive any different when the lights are on.
TimSawf
864
South Manchester
I think those are the three warning lights that come on after the battery has been disconnected and they need to be reset by driving a short distance. It might be an interruption in the power supply.
optim8
I had this the other day, dealer says its my PAS going to cost £1350!
:( Tell me more? Did you get all 3 lights come on?
Strange one, I did Seat to take a look last time I took it in, they apparently did some 'fiddling' under my steering column and said at the time to come back if they came on again!! Battery hasn't been disconnected though.
Deleted member 74601
I thought these 3 lights were associated with the ABS sensor fail?
optim8
Who knows!!! But surprise surprise because the weather is slightly warmer today no warning lights at all this morning:blink:
Wondering I've got some sort of doggy connection or something. Just where to look!
Got a Bluetooth ODB2 Scanner on order so going to plug that in and see what I can find.;)
mark-cupra
FR TFSI
Sep 11, 2010
538
Stoke-On-Trent
I disconnected my battery the other day and had these 3 lights come on, they went off after driving about a mile though and havent come back since, one thing to notice if is something to do with the battery or power does your clock reset to 0:00 and if you have an after market radio does that reset?
surajb1
"FR"
Oct 21, 2012
137
UK, Birmingham
Best thing to do is check with vcds, I have both the odb2 bluetooth and vcds and the fault codes vcds found the odb2 bluetooth scanner didn't.
Sent from my GT-I9300 using Tapatalk 2
