Power runs Octy VRS
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Mate came down earlier for some power logs as he taught his car felt slow. His is standard aprt from air filter and upgraded dv
Think something we both have in common :rolleyes:
Code:
Group A:	'003				Group B:	'020
	Idle speed	Air mass in	Throt Angle	Ignit Angle		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME	700-820 rpm	2.0-4.5 g/s	0.2-4.0%	0-12 BTDC	TIME
STAMP	 /min	 g/s	%	°	STAMP	 CF	 CF	 CF	 CF
0.48	1520	24.42	67.5	8.3	0.88	3	4.5	4.5	6
1.29	1640	27.22	68.2	13.5	1.79	3	4.5	7.5	6
2.19	1800	33.97	98	8.3	2.59	3	6.8	7.5	8.3
2.99	2000	41.56	100	4.5	3.41	2.3	6.8	6.8	8.3
3.9	2200	50.03	100	3	4.3	2.3	6	6.8	7.5
4.7	2400	51.67	100	6.8	5.12	2.3	6	6.8	7.5
5.61	2600	58.28	100	9.8	6.01	2.3	6	6.8	7.5
6.41	2840	64.89	99.2	15.8	6.93	4.5	6	6	6.8
7.33	3080	69.17	100	12	7.73	7.5	5.3	6	6.8
8.16	3320	76.94	100	9.8	8.64	7.5	5.3	9	6
9.13	3600	83.92	100	12.8	9.53	6.8	8.3	9	6
10.05	3800	86.61	100	12.8	10.45	6.8	8.3	9	6
10.85	4040	92.81	100	15	11.26	6.8	8.3	8.3	9
11.74	4280	99.11	100	12	12.16	6	8.3	8.3	9
12.67	4560	105.89	100	16.5	13.15	6	7.5	8.3	8.3
13.56	4800	112	100	12	14.02	6	7.5	7.5	8.3
14.51	5000	118.56	100	15	14.97	9	7.5	7.5	8.3
15.47	5280	125.39	100	15	15.88	9	6.8	6.8	7.5
16.38	5520	133.33	100	13.5	16.78	9	6.8	6.8	7.5
17.22	5720	136.06	100	14.3	17.69	8.3	6	6.8	7.5
18.09	5920	138.31	100	13.5	18.59	8.3	6	6	6.8
19	6120	140.44	100	17.3	19.4	7.5	9	6	9.8
Code:
Group A:	'115				Group B:	'031
	Engine Speed	Engine Load	Spec. Boost	Actual Boost		Lambda Factor	Lambda Factor
TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar	TIME
STAMP	 /min	%	 mbar	 mbar	STAMP
0.37	2000	97	1650	1300	0	1.07	1
1.28	2160	112.8	1530	1490	0.77	0.97	1
2.18	2360	110.5	1510	1480	1.78	1	0.96
2.99	2560	112	1540	1510	2.58	0.95	0.95
3.89	2760	117.3	1560	1540	3.49	0.94	0.95
4.8	3000	120.3	1590	1560	4.29	0.93	0.95
5.7	3200	123.3	1590	1600	5.3	0.94	0.95
6.51	3440	123.3	1580	1590	6.1	0.93	0.95
7.41	3640	122.6	1600	1590	7.01	0.94	0.95
8.45	3880	120.3	1620	1600	7.81	0.93	0.95
9.33	4120	121.1	1630	1610	8.91	0.93	0.93
10.32	4440	123.3	1630	1610	9.84	0.9	0.91
11.23	4680	122.6	1630	1620	10.74	0.88	0.89
12.05	4880	122.6	1630	1600	11.65	0.86	0.88
13.06	5160	123.3	1650	1620	12.54	0.83	0.83
13.9	5360	124.8	1660	1610	13.46	0.8	0.8
14.77	5560	124.8	1660	1630	14.35	0.77	0.77
15.66	5760	124.8	1630	1620	15.26	0.77	0.77
16.67	5880	104.5	980	1610	16.18	0.76	0.77
Code:
Group A:	'118				Group B:	'032
	Engine Speed	Air Temp In	Boost Dut Cyc	Actual Boost		Idle O2 Adapt	Run O2 Adapt
TIME	700-6800 RPM	<=110 C	0-100% 	<=1800 mbar	TIME	-10.1	-10.1
STAMP	 /min	°C	%	 mbar	STAMP	%	%
0.5	2000	19	0	1490	0	-1.3	-0.8
1.41	2160	18	72.9	1450	0.93	-1.3	-0.8
2.21	2360	18	62.7	1540	1.81	-1.3	-0.8
3.02	2520	18	70.2	1570	2.61	-1.3	-0.8
3.92	2760	18	63.5	1580	3.52	-1.3	-0.8
4.95	3000	19	62.7	1580	4.43	-1.3	-0.8
5.84	3240	20	64.3	1600	5.42	-1.3	-0.8
6.83	3480	20	64.7	1600	6.35	-1.3	-0.8
7.74	3720	21	64.7	1600	7.25	-1.3	-0.8
8.66	3960	21	65.9	1620	8.14	-1.3	-0.8
9.47	4160	23	66.7	1620	9.06	-1.3	-0.8
10.38	4400	24	67.1	1620	9.95	-1.3	-0.8
11.36	4680	24	67.8	1610	10.88	-1.3	-0.8
12.17	4880	26	68.6	1620	11.77	-1.3	-0.8
12.99	5080	27	69.4	1630	12.57	-1.3	-0.8
13.89	5320	29	71.8	1610	13.39	-1.3	-0.8
14.8	5520	30	73.7	1620	14.29	-1.3	-0.8
15.69	5720	32	74.5	1610	15.2	-1.3	-0.8
16.51	5880	33	74.1	1600	16.09	-1.3	-0.8
TBCupraT
Limp Mode Squad ™
Hi Mate,
Had a look at your logs and everything checks out for a stock 180bhp Octy.
MAF's good. 140x1.31 equates to 183bhp
Boost follows well. Builds and sustains 9psi.
There doesn't seem to be any major leaks according to block 032.
The intakes are low as expected on low boost.
Fuel trims look fine across the board.
Block 020 does look odd.
I would suggest putting in a full tank of optiplop and resetting the ecu.
Redo block 020 and post back.
Hope this helps put your mates mind at rest.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
disconnect maf and relog cf on block #020.
what grade fuel you running? way too much pull for stock.
Big_daddy
Oct 20, 2006
3,930
Brummy
he using standard 95 fuel, his standard, god knows what will show if the car was remapped. He getting the same amount of timming pull as me :-o
Big_daddy
Oct 20, 2006
3,930
Brummy
Plus he getting very rough idling on cold starts but settle down when temps are normal. accroding to logs for the maf, boost are fine, does this only leave the temp sensor?
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
It may be worth trying the MAF. I had to look at some logs lately and couldn't for the life of me find a problem and it turned out to be a dud MAF. Even with strong readings from it.
Big_daddy
Oct 20, 2006
3,930
Brummy
is this related to the rough idling on cold or high timming pull? :rolleyes:
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
It could be mate. Its worth trying Bills advice.
I agree with TB Cupra T that the logs look ok, but I have learned that this can still be the case with a dodgy MAF. It would be my first check to be honest.
