power reading
bridgestone1234
If I am correct I traceed a data somewhere that some engine controllers have engine power reading at measuring blocks. Is this true or not?
Uwe@Ross-Tech
392
www.Ross-Tech.com
Some ECUs have torque, and if you know RPM (which you do) then you can calculate power from torque.
Caveat: Torque is not actually measured by the ECU, it is calculated by the ECU based on air flow and other parameters.
-Uwe-
bridgestone1234
can you share with me which controllers do have these readings.
BTW; isn't engine load aslo torque produced/torque that can be produced in percentage?
