Probably sound stupid here but im not a machanic
What do you need to do to remove it? do you need to buy anything ??
Whats it meant to do when you remove it??
You'll need a Y or T piece from B&Q for the piping.Also some vac piping from samco or silicon hoses.
This by passes a valve and reservoir that are used by the ECU to open/close the DV on demand. So even when you are full throttle, if the ECU wants it can open the DV and vent boost.
Bypassing these stops this, and also speeds up the time time it takes for the DV to open, vent boost and close again.
i found a few dont get me wrong, (including the one above) but their all very technical, i need a stupid proof guide if you know what i mean
if in doubt, don't do it
but it's so simple & easy - if you can't do it, you must have velcro shoes since shoe laces are harder to tie.
print it off, and stand with it infront of you engine.
lol, will do that
How long does it take?
