Power Bluetooth Mirror Via Car Interior Light
hc97mg2000
10
Hi I have just purchased a Bluetooth Rear View Mirror (Handsfree Device). It came with a cigeratte lighter charger But I would like to permanently power this device so I do not havce to charge it all the time.
can I do this via the Car interior light just above the rear view mirror. Any guides or sugestions would be great. Thank you in advance
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
Not easily as there is no switched ignition positive up there. You could tap into the headlight switch, run the lead up your a-pillar, across roof lining to rear view mirror. At the headlight switch you need to tap into the switched +12v and earth.
hc97mg2000
10
Thank you very much for your repsonse.
Is it possible To provide a detailed guide. I have fitted a Engine Start switch before but I am no means an expert.
If you could provide a guide that would be excellent.
Thanks in advance and for the response
