I remember reading this question after i got my 1.4 sport which had the three rotary dials and wanting to swap them over, now having the climate control i think i would rather the dials! With the climate i cant find the sweet spot, its either too hot or too cold and end up taking my eyes off the road to change it opposed to dials which i could change with out looking.
and as soon as you press auto, the aircon comes on. It's annoying
I use Auto on the Climate Control all the time set it to 24 (Cos it's cold just now) and leave it alone, I run it on "Econ" mode because it switches off the compressor and saves fuel.
I only use the "Non-Econ" mode when de-misting the windows cos it takes seconds rather than minutes.
I actually find it's too hot If I have the same temp selected and with vents to windscreen and floor.
.G.
.G.
I've actually just noticed that no-body has mentioned the fact that the Climate Control electronically controls the air-vents with servo motors, either Automatically or when you select the particular air flow direction button.
So I guess you would have to change both the control head unit, and the box that controls the air vents themselves.
So it may turn out to be a bigger job than it seems, wiring....fuses.....
.G.
I think it's coupled magnetically and runs on a clutch, at least some of the VAG ones do. There is a noticeable difference in engine load and therefiore performance and economy if I don't use ECON all the time.
"some of the VAG ones do" - yes, but as I said not this one! The bonus with this type, and hopefully it is the way forward, is that the compressor seals get kept "wet" with circulating system oil so do not start leaking through lack of use. Also no elctro-mechanical clutch assembly to fail!
OK not yours, but mine does apparently
