Poor radio reception after fitting aftermarket head unit
fishtoasty
Cupra R Pimpin
Sep 4, 2005
82
Manchester
after fitting an aftermarket radio to my lcr my recption on the tuner seems really poor. its all connected up properly as far as i am aware. any ideas what could be causing this issue. i am sure it was ok for a while after i fitted my radio. now the reception is just rubbish.
any ideas would really help. thanks.
ross
fishtoasty
Cupra R Pimpin
Sep 4, 2005
82
Manchester
do you have a link to a picture of what they look like as i thought i already had one but maybe not haha
thanks for your quick response
ross
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
DannyC87
Mar 4, 2008
3,459
it should sort it. the original seat radio has an aerial amplifier built in; aftermarket ones don't tend to; so an external one does the job. You need to tap the blue wire into a switched live in the radio harness. Blue wire in the harness will work from memory.
Sep 29, 2008
242
Midlands
My standard aura unit reception is not the best. Out of interest, if I fitted one of the above amplifiers would it boost the reception too much and have a negative impact?
DannyC87
Mar 4, 2008
3,459
not sure to be honest... one way to find out ;)
car_guy143
183
Leyland, Lancs, UK
The signal booster is in the aerial booster itself, not the radio (factory or aftermarket). The factory fitted radio just has an output that sends power up to the booster in the aerial. Aftermarket radios don't do this as not all car aerials have a booster built in. Buy the adapter and it will definately improve your reception :)
DannyC87
Mar 4, 2008
3,459
i stand corrected :)
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
If you have the standard aerial with an after market headunit, you need to make sure there is power going to the aerial, as it was standard, or it just wont work, ok it will but it will be a weak signal.
You need to make sure number 5 in the bottom block is getting power from the aftermarket unit
By lee69
