poor boost
Jul 4, 2007
1,674
bristol
go a little problem with my boost at the moment. it boosts up to 1.5 bar then with my foot still planted slowly creeps down is this normal? i have vagcom and it shows nothing?
tommy2008cupra
yeh pretty much it wont hold boost for long do sum logs and put them on here if you are concerned
Jul 4, 2007
1,674
bristol
cheers guys also im running a forge 007p dump valve and was thinking of changing the spring compression to see if it holds boost better is that a good idea?
tommy2008cupra
wat turbo you running? you prob wont need to change the spring
tommy2008cupra
basically its a small turbo and will not hold 1.5 bar for long, sounds about right to me
Cupra Ken
more boost = more rattles
Sep 7, 2008
66
st ives, cambs
As said mate it's only a small turbo mine peaks about 1.5 1.6 bar and after about 5k tails off to hold just over a bar. that big boost spike is where you get all your tourqe from.
