the car keeps getting to certain revs then not going any further which i beleive is called limp mode, i have replaced the maf sensor but its till doing the same
could be a boost leak or sticky turbo.. many things really. you need to find someone nearby who has VAG COM on a laptop to check what fault code is reported when it goes into limp mode. if no faults are reported then its time to do some logging.
