Please need some help - P0087 - fuel pressure low
Abs2788
26
West Yorkshire
So, my cars stock currently, was hoping to get to stage 2 at the moment, still getting the dreaded fuel pressue too low - P0087 while stock running up to 154bhp on dyno before fuel cuts off on what is a 2.0tfsi (200bhp). This is what ive done so far to eliminate:
  • Brand new Hp Fuel pump from dealers
  • Audi RS4 valve (cant remember full name of it)
  • Upgraded fuel lines from old banjo nut style to hose
  • Changed Cam follower
  • PVC Upgrade to type N
The only thing i can think of trying is changing sensor on bottom left (low pressure) as this doesn't come with new pump and sensor on fuel rail. I shall change the fuel filter again while im at it.
Anyone think of any ideas or kind to share anything they found helped as it is becoming a serious money pit on just this fuel issue. The readings i got for the sensor by the fuel tank was normal.
Many thanks guys
Abs2788
26
West Yorkshire
Update: changed fuel rail sensor, no joy. Getting another code which I have been getting now and then - camshaft timing position. Think we are boiling to the timing but going to start with changing the camshaft valve behind the fuel pump, see if this helps.
Anyone recommend a decent garage to carry out work on cam chain timing if replacing the valve doesn't work in West Yorkshire, can't imagine what delears would charge
