Placement of axle stands?
Oct 31, 2006
870
Cambs
Going to be fitting some coilovers this week and wondered where the best place for axle stands are at the rear?
At the front i'm going to put them on the subframe where the ARB is, is this ok?
Cheers Tim
Oct 31, 2006
870
Cambs
OK cheers, i take it you meen on the front, on the rear is there anything that is suitable like the front subframe?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
if you're fitting rear suspension, you will want to support your car on the body, not the rear beam.
because when you remove the struts, the car will fall on it's arse.
behind the rear jacking point cover is a square section - perfect for axle stands
at the front, you don't want to support the subframe, since you'll be needing to lower it - you'll need to support it elsewhere (I use the sills with a block of wood with a cut out)
Oct 31, 2006
870
Cambs
Cool, cheers fella's i will find out in the morning if i get them in the right place if not it could all go horrible wrong!!!
i don't suppose any of you know what torque settings the suspension is done up to? it's a bit of topic i know.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
you'll be hard pushed to do the rears at the same time, since one shock will be shorter than the other
