Pink Calipers!!
ponydust
51
Cambridgshire
Hi Everyone
Brought my 2003 Cupra 210 on Sunday and all i can say is i wish i'd got one instead of my honda ctr a long while ago, you can't even compare them!! :D
Any how, i seem to have slighty camp brake calipers, the two back ones are slightly pink! I've seen some brake caliper paint on e-bay and was wondering if this is easy enough to do myself (i'm not very good at anything practical!!) Eg, rubbing down etc? Has anybody done theirs?
Mark
awelch
Mar 1, 2006
151
I agree t-cut helps, especially if you use the colour coded Red T-cut colour restorer not the original.
If all else fails buy folia tech heat resistant caliper paint, comes with special cleaning solution.
ponydust
51
Cambridgshire
I think the problem is different...The two front calipers are shiney and not a matt finish like the back ones. On closer inspection the front ones are flakeing and it looks like a laquer of some description has been sprayed on them. Where they are flakeing i rubbed parts off and the matt red is underneath??
1. Should they be shiney or Matt?
2. if they should be matt as the back ones are, how do i remove the laquer safely??
Thanks!!
