We upgraded the image resize software, this is essential as we all know there are a bunch of eejits out there that can't resize their images to suit. So the software does it for them.
However the new software also incorporates litebox, which means any pictures are opened up in a pop-up viewer and you can cycle through all the images in the thread.
This works fine for all IMG coded files without links. But the software also incorporates a workaround for those images that have url links applied to them.
Here is a quick guide.
IMG Code - Where you see these
{} in the code below replace with
Example of an IMG without a link (Original Image is 1024x681)
Code =
{IMG
}url or web address of image goes here{/IMG
The result of using the code shows the image is resized in the post and if you click the image it should open to the full size in the litebox viewer.
Example of an IMG with a link, and why IMG with link no longer works properly
If you do an IMG with a link. Like the small thumbnail example below. This would of taken you to the SCN homepage if the url link it contained worked as it did before. However because the IMG code is now linked to the litebox it will no longer will work correctly and will just open in the litebox or even crash out IE in some reported cases.
Code =
{url=
http://www.seatcupra.net} {img
}url or web address of image goes here{/img
} {/url
Example of an IMG with a link using the IMGLINK code instead
This is essentially exactly the same as above. Except where ever {IMG} appeared in the code we now replace it with {IMGLINK} instead. This now disables the litebox viewer and allows the original image link to be opened as normal. If you click the image below, it should now take you to the SCN homepage.
Code =
{url=
http://www.seatcupra.net} {imglink
}url or web address of image goes here{/imglink
} {/url
[imglink]http://www.seatcupra.net/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=21558&g2_serialNumber=2[/imglink]
Hope the above helps
