pd130 injector torque settings
bedford8256
recently bought a pd130 ibiza tdi, had a few problems with diesel getting in the oil and leaking out quite alot, upon inspection weve noticed no1 and no3 injectors are leaking diesel into the engine, iv got new O rings ready to put all the injectors back in, does anybody know the torque setting to hold the injectors down? thanks
engine code is asz and its a 2003 03 tdi ibiza pd130
bedford8256
Bumppppp also need torque settings for the shaft above the injectors
bedford8256
12nm at 270degrees for the injector clamps, and the rocker shaft is 20nm at 90 degrees
