Gavin NI
Hi all,
I'm after some expert advise on tuning my ATD 100 PD engine.
This is the car
I have fitted the following to get 159.6 bhp and 259.6 lb/ft with graphs that are all over the place
PD 130 injectors
PD 150 turbo
PD 140 pressure converter
PD 130 maf housing, maf and all metal intake pipes and airbox lid
MK V Golf R32 DSG intake piping to air box
Custom made EGR deletion
Miltek cat back exhaust
Chipped UK custom mapping running 19-21 psi according to my boost gauge
Mod's on way or in garage...
150 PD ECU
Miltek Downpipe
Entire MKIV Golf 150 PD FMIC and map sensor
Uprated clutch
We can't seem to be able to get the car to run right. There's zero smoke and the boost is all over the place. I'm trying to go down this OEM route first before I go for up-rated turbos, FMIC's, etc etc.
Can any of the experts shed any light on why we can only achieve 160 bhp from these mods so far and what would be causing the boost problems. Is it down to the mapping or a the OEM ATD ECU which will be replaced very soon by the 150 PD item.
Thanks for any help...
Gavin
This is the car
PD 130 injectors
PD 150 turbo
150 PD ECU
Miltek Downpipe
Uprated clutch
Gavin
