andy91
10
Hello, having strange problem while using window controls on drivers side which can control al 4 windows.
When I press button for passenger window, it sometimes controls window behind passenger (right back), when I press down it starts going down then immediately passenger window starts going down, after that right back window starts going up - it’s all mixed and directions are wrong. Not working as expected at all.
Same if I use button for back right window, sometimes it control passenger window and after I press it again to go down, it goes up or even sometimes both windows starts to control in wrong directions.
Everything works fine when passenger side button is used, or button on right back door.
So it’s something with driver door control module.
Anyone has similar situation?
Sounds like you've definitely got gremlins there.
Both my current and previous Cupra Atecas have been fine with the window switch.
Sorry I can't be of more help.
Guy
Sent from my XQ-BQ52 using Tapatalk
Okay, thanks for answer.
If someone else had similar issue, please let me know.
I’m waiting for vcds to check it out.
