I've just replaced this 90 degree bend because one of the beyonet lugs (on the sleeve part) going into the EGR assembly had sheared off. Yes the sleeve is bonded to the black tube and it's one part.
Pt No. 6LL145838 and cost £28.31+VAT from Ted Johnson
You may need a new clip as well depending on how worn it is. I don't know the part number but bought a clip for another hose and that was £0.98 +VAT
It's just wear and tear, it happens over time, contstant on/off pressure wears it down.
When I fitted my new one, I filed the lug to make sure it had a 90 degree angle against the clip, I also ruffed up the clip where it comes into contact with the lug, if you know what I mean. I don't like the design to start with, It would be better with a hose clamp IMO.
