Part no request
kid709394
55
Sydney, Australia
Hey Guys...
i broke both sides light bulb cover.. anyone knows the part number? as there aint any number on the plastic, all it says is Valeo, Made in Spain, R and >PC<
Anyone has EKTA or Repair Manual ?
SpareMan
354
What do you mean? The side light is part of the headlight. Do you mean the indicators? Or the indicator repeater on the wings? Or the rear lights?
Are you in the right section? 99 Ibiza is most likely a Mk 3
kid709394
55
Sydney, Australia
98 built cupra .. and yes its a mk2
its the plastic cover (black) that protect water from getting to the front headlights.
Sorry for the lack of details. and the cover is located under the bonnet, right infront of the airbox. with a clip at the top of the cover. my clips are broken.
SpareMan
354
I believe you mean the protective cap, for single beam headlight this is 6K5941607 (1 for each side), if you have twins there are 2 separate ones, 6K0941607A & 6K0941607B. ETKA also lists a retaining spring, part number 6K0941125 but it is not clear if this is the clips you are looking for
kid709394
55
Sydney, Australia
thanks spareMan... got some pic are they the same one as u said? notice is clips is broken and it is plastic, it got no spring around it.
SpareMan
354
eeerrrrrmm doesn't look much like the ETKA picture. Are there any part numbers on the part?
SpareMan
354
no part number...
aha i should pay more attention, you said it right at the top of the thread. Anyway i spoke to a guy in the know and they are the covers that I listed part numbers for earlier. Unfortuneatley ETKA is not clear about the clips, it implies they are what you want but ETKA can be vague at times
kid709394
55
Sydney, Australia
please do let me know if you happen to find out... i need to replace the whole part not just the clip, the clip is actually part of the plastic cover.
SpareMan
354
Then order the cover, cant fail!
SpareMan
354
I told you the part numbers earlier in the thread
"for single beam headlight this is 6K5941607 (1 for each side), if you have twins there are 2 separate ones, 6K0941607A & 6K0941607B."
SpareMan
354
Those part numbers are the headlight covers as you pictured. ETKA illustration is different but don't worry about that, a lot of ETKA pics are generic to cover all makes and models in VWG so the pic I looked at might not even be for a Mk 2 Ibiza
