Parking Assist Button
Don1961
213
118
Hi..... I only have rear parking sensors, which I've activated with OBDEleven, so I get the display when reversing.
If I fitted the Parking Assist switch, next to the stop/start switch on Air Con panel, would it work properly in selecting/deselecting the sensors?
Lozzy15
Mods mods mods
577
391
Ilkeston, Derbyshire
Hi,
It is possible. I think you may need to change something in VCDS/OBD Eleven/Carista but I honestly cannot remember as it's been a while since I did it.
I made a guide to fit the button and front sensors but you can just follow the first part to fit the button and the programming part at the end of the guide
Reactions: Don1961
Don1961
213
118
Hi,
Thanks. Hopefully it will be a straight swap with the button. Just hope the wiring is there and works with just the rear sensors.
