Painting my calipers but went wrong.....help
Deleted member 12466
Hi everyone
I brought some savage red calpiber paints, but the colour has came out dark pink!!!! what happened, was it the product fault or something i didnt do right??? I was thinking of getting some red hammerite to paint over it, is this a good idea or not?
BEOWULF
I am BEOWULF !!!
Mar 18, 2006
1,186
I AM IN FRONT OF YOU
hammerite will cover it m8 but it will look pants i would get some paint remover on and start again
how did u clean them first m8 as most work is in preparation i think the paint as reacted with something u have used to clean them with.
i used the cleaning arisol can that came with it. let that do its business for about 10mins ( thats what the instruction said) then started to paint. As soon as i slapped on the paint it went pink, but as it was getting dryed throughout the day it ended up dark pink.
What will happen if i just used hammerite over it????
ChrisUK
Eat My Smoke
Oct 20, 2004
2,258
Liverpool, UK
I've used Hammerite to paint my calipers on my last 3 cars and it's been great.
I used a wire brush to get all the crap off I could, then painted them carefully with Hammerite. Normally takes about 3 coats to look super & last for ages :)
GrayT
I'm Old
Jul 7, 2004
812
London
Lots of people have used hammerite and recommend it over proprietary calliper paints. I would go for it rather than going around with pink callipers!
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
You should be ok to paint straight over with the Hammerite paint, but I'd test a small, inconspicuous area first. Do a small section, let it dry and see how it turns out. If ok, do the rest. If not, remove the original paint and start from scratch.
Did you use a wire brush and sand paper to remove any surface rust before starting this job? If not, it might be worth doing that before using the Hammerite anyway.
I used a bit of sand paper to get the crap off and then this cleaning spray that came with it. I've just checked this morning and its got a little more darker this morning, but no were near red. I'm just gonna have to get some hammerite stuff and sort it out then. What a nightmare, its def put me of painting calipers again!!
