P0444 fault code
luke2702
Cupra K1
Aug 22, 2010
462
Bolton
I need a bit of assistance!!!
Had Downpipe fitted and had car mapped to stage 2. Driving no problems, suddenly had CEL come on scanned it and the code P0444 Evaporative "emission control system purge contrl valve circuit open".
Can any one shed any light on what the fault could be. Engine is 2.0tfsi
Aok82
155
Finland, Uudenmaanlääni
Could be that your N80 valve has jammed open. Quite easy task to change it.
good thing that it does not affect your driving or engine working on any way so you can drive safely until you fix it.
im having similar problem with (in correct purge flow) and have no clue whats causing it.
luke2702
Cupra K1
Aug 22, 2010
462
Bolton
All sortrd it was my f**k up i was pullin fuses for my head light last night and pulled engine management light fuse out and putnit back in wrong place!!! Numpty i am!!!
Jay sx
32
7
Thread revival , I have the same fault code , but did remove and check fuses , so now worried I've put them back wrong. Does anyone know what fuse location the engine management light fuse is , as mentioned in this post . Thanks
kizvincent
8
Which fuse is this for this circuit ?
SWANSWAY CUPRA Dealership
